You are here: PSPad forum > Developer forum - new builds > PSPad 4.5.0 (2175) English
Posted by: RenéH | Date: 2005-12-26 21:41 | IP: IP Logged
Great! I'll be patient and keep an eye on the betas.
Thanks,
René
Posted by: Nelson | Date: 2005-12-27 02:30 | IP: IP Logged
> pspad wrote:
> If you switch from the text view into Hex view and you are
> using the unicode encoding, PSPad will display you in the hex
> editor 2 bytes per char.
> No, it isn't bug.
No, it shows "DOS CodePage : ANSI" in the status bar.
Posted by: squonk | Date: 2005-12-27 14:10 | IP: IP Logged
Hi Jan!
Many thanks for this Christmas release!
The strange behaviour I've reported in 4.5.0 (2164) beta about the mouse wheel scrolling is still there. In the post where I've wrote about the problem, some post after mine you wrote: "It's problem of the Synedit component - editor base", but I don't understand if yours is a replay to my problem or something else...
Many thanks again!
Best wishes!
Posted by: RickH | Date: 2005-12-27 15:53 | IP: IP Logged
You left out the "spell" directory on the full install. (This also had the "lorem ipsum" dictionary in it.) Great work. PSPad is my default editor for just about everything.
Posted by: Ignatius | Date: 2005-12-30 23:49 | IP: IP Logged
Hi!
When the scrollbar reaches the last (or first) line, the text in the page blink if continue scrolling.
PS. Sorry for my poor english
Posted by: pspad | Date: 2005-12-31 07:48 | IP: IP Logged
For now set in Program settings / Editor same or the higher scroll lines number then is set in the mouse properties control panel
Posted by: yue | Date: 2005-12-31 11:36 | IP: IP Logged
Thank you very much for the great editor.
I have one feature request and one minor bug report.
1. Can you provide an option that allow the ReadOnly mode in PSPad to be in sync with the file ReadOnly attribute? I work with source control system, so the files' ReadOnly attribute changes frequently as I check in and check out files. I wish that PSPad can detect that the readonly file attribute has been changed by other programs, and then change the readonly mode in PSPad accordingly. I think that the current setting "RO mode changes file attribute" can be replaced with "RO mode in sync with file attribute". In this way, whenever the user changes readonly mode in PSPad or other programs change the readonly file attribute, PSPad always keeps the attribute and the mode the same.
2. IN the file list tab of the tool panel, the item corresponding to the active file is always selected. But if I open a new file (by drag-and-drop, or by right mouse click, or by selecting the menu), the new file is open and active, but the selected item in the file list tab does not change.
Thanks
Happy New Year!
Posted by: squonk | Date: 2005-12-31 17:48 | IP: IP Logged
> panel
Thanks a lot!
It works!
Thanks again and happy new year!
Posted by: DJ N-4ceR | Date: 2006-01-01 02:15 | IP: IP Logged
Sometimes I need to copy Subroutines. Would be nice if the code explorer could copy/paste or mark complete Subs.
Posted by: pspad | Date: 2006-01-01 09:14 | IP: IP Logged
Pogram settings / Program behaviour
Uncheck [x]R/O mode changes file attribute
You can edit R/O files in PSPad (menu File/ReadOnly or Lock button on the toolbar) and PSPad will keep file attributes
Press the synchronize button on the File explorer toolbar
