You are here: PSPad forum > Bug report / Hlášení chyb > Re: "Whole Words Only"
Posted by: Peter.eisentraeger2 | Date: 2022-11-21 10:43 | IP: IP Logged
rev 741; In Search and Replace the tick for "Whole Words Only" is always on after restarting pspad
Posted by: pspad | Date: 2022-11-21 10:45 | IP: IP Logged
hello
Ensure you didn't unpack PSpad into Program files from developer build only.
PSpad has no right to write into this folder.
Start PSpad as admin, open program settings / System integration and check "Multiuser environment"
Save setting, close PSpad and start it normally.
Posted by: Peter.eisentraeger2 | Date: 2022-11-21 15:08 | IP: IP Logged
I have often unzipped developer builds. This was the first time pspad behaved that way. I did the admin thing and now it works. The multi user environment was already active.
Thanks!
Posted by: pspad | Date: 2022-11-21 16:01 | IP: IP Logged
There is no problem to unzip developer build over existing install. But there is a big difference when you unzip developer build into empty folder.
Developer build contains changed files only - you miss lot of functionality. And when you unzip it, it behaves as portable version - all settings are stored into PSPad folder.
If you don't like installer, unzip last full version and overwrite it with developer build. And make settings, I suggested in the previous answer - set Multiuser environment. This will store settings into %UserProfile%\PSpad instead of the PSpad folder.
