You are here: PSPad forum > Bug report / Hlášení chyb > EAccessViolation 0000000000AE848D
#1 EAccessViolation 0000000000AE848D
Posted by: Terraustria | Date: 2021-04-30 17:21 | IP: IP Logged
Hi there!
I am using PSPad for some time now but today I cannot open it anymore. When I start it I instantly get an error message with the only option to terminate it :(
Hope someone can help:
Exception class:
Exception address:
Stack list, generated 30/04/2021 19:15:20
Thank you for your time to report this issue!
Please don't post exception report into the forum.
Send it to my support address (see Help > About).
And please add a short description what you did when exception occurred,
e.g.: close file (generic advice, nothing special to you)
In some cases I am else not able to recognize what caused exception.
- What did you do: ....<accurate step-by-step instructions here>..
- How did you do: by keyboard press, by menu, context menu, macro
- You had expected to get: ....
- But you got instead: .....
Thank you.
Program : C:\Program Files\PSPad editor\PSPad.exe 5.0.6 (589)
System : Windows Server 2019 Server x64, Version: 10.0, Build: 4563,
Processor: Intel, Intel(R) Pentium(R) CPU J3710 @ 1.60GHz, 1600 MHz MMX
Display : 1680x1050 pixels, 32 bpp PPI: 96
Skin : Windows
Active Controls Hierarchy:
TPSSynEdit ""
TfChildEdit ""
Edited 2 time(s). Last edit at 2021-05-04 09:52 by Stefan.
#2 Re: EAccessViolation 0000000000AE848D
Posted by: pspad | Date: 2021-04-30 20:21 | IP: IP Logged
Please don't send exception reports into foru. send it to support mail.
I see problem with that PSpad tries load file you open last time.
Visit PSpad developer forum and update to current 5.0.7 build.
