You are here: PSPad forum > Bug report / Hlášení chyb > Starting SpellChecker crashes PsPad with Bulgarian library
Posted by: krasi533513 | Date: 2021-04-14 08:08 | IP: IP Logged
Hi there, and many thanks for your very useful PsPad!
I've tried to use Bulgarian Spell Check, but it crashes the PsPad. When I change dictionary to something else, e.g. English, then it works correctly.
I'm using 64-bit version of PsPad 5.0.6, last published on your site.
Application Error
Exception EAccessViolation in module PSPad.exe at 0000000000152E16.
Access violation at address 0000000000552E16 in module 'PSPad.exe'. Read of address FFFFFFFFFFFFFFFF.
I've checked the same on another computer, with PsPad 5.0.6/32bit, and the same library works fine there, so it looks like the problem is with 64-bit version only, but still English dictionary works well on both 32 and 64 bit versions.
Posted by: pspad | Date: 2021-04-14 08:33 | IP: IP Logged
This problem was fixed in 5.0.7 vrsion
forum.pspad.com
Posted by: krasi533513 | Date: 2021-04-14 08:50 | IP: IP Logged
OK, I've updated it now...
So it started the spell check, new file with only a couple of words to test, but when I tried to close the PsPad it crashed againt.
Application Error
Exception EAccessViolation in module ntdll.dll at 000000000002151D.
Access violation at address 00007FFF2F5F151D in module 'ntdll.dll'. Read of address FFFFFFFFFFFFFFFF.
I've tried this again, and it happens again...
Posted by: pspad | Date: 2021-04-14 09:17 | IP: IP Logged
I will check it
Posted by: pspad | Date: 2021-04-16 14:25 | IP: IP Logged
I found a problem with spellchecker and I hope I fixed it. I don't get any error when finishing PSPad, changing dictionary, e.t.c.
Fix will be available this weekend.
I am suspicious that all problems are caused new compiler, cause from the time I upgraded developer environment, I am fighting with strange exceptions.
Posted by: krasi533513 | Date: 2021-04-16 15:26 | IP: IP Logged
OK, I will check it again, when the new build is published
Posted by: krasi533513 | Date: 2021-04-19 09:43 | IP: IP Logged
Hi there!
I've checked the new 64-bit version of build 5.0.7/597, and it works fine for me. The commented issues are covered.
I would be happy if I can help with other errors/tests.
Thanks!
