You are here: PSPad forum > Developer forum - new builds > PSPad unicode 5.0.7 (593) English
Posted by: pspad | Date: 2021-04-11 20:11 | IP: IP Logged
Download links:
SHA1 hash:
2d58ab09a17026bc888b86d61731052f49e6e7f9 pspad507b593.zip
46d0e57ed4fbaf7e1dc3effe71df89c0ea9dd7d0 pspad507b593x64.zip
Changes to 5.0.7 (586)
News:
MS SQL zvýrazňovač - přidány nové datové typy
Nastavení přavopisu - přepínání slovníku v 64b verzi
Opravy spojené s překreslováním při otevírání/zavírání souborů
Posted by: pspad | Date: 2021-04-11 20:24 | IP: IP Logged
For testing purposes first version of the PSPad updater is available
Description of functionality is in the included readme file.
Unpack it in the PSPad folder into Updater subfolder. Structure should be:
pspad.exe
- Updater
--- Updater.exe (and rest of the files)
If you want to test without touching your installation, copt PSPad folder somewhere and test it there.
Feedbacks are welcome.
Posted by: PGomersall | Date: 2021-04-12 19:51 | IP: IP Logged
Jan tested updater with 64bit and it works; correctly pulled 593.
Questions:
I presume you plan on calling it from within PSPad's Help menu, possibly replacing the current Check for updates in a later release?
Will the tool work from command line, say called from a scheduled task?
Pete
Posted by: pspad | Date: 2021-04-12 19:59 | IP: IP Logged
Yes, updater will be called from inside PSPad, I will integrate it to the update check.
And yes, there will be possibility to call it from command line, e.g. from task sheduller.
Problem is impossibility to update running PSPad.
This is a field test of basic functionality, if I didn't forget anything important.
Posted by: PGomersall | Date: 2021-04-12 20:14 | IP: IP Logged
OK, I understand the issue if running. Maybe something like the Chrome updater that waits until Chrome closes or system restarted?
Posted by: pspad | Date: 2021-04-12 20:31 | IP: IP Logged
Yes, it's thing of future.
Another problem are necessary elevated fights to write into program files folder. Chrome has service for update.
I can run updater and request elevated rights. Close PSPad, update it and start it back.
Posted by: Andreas | Date: 2021-04-13 11:03 | IP: IP Logged
Hello Jan, does the version now stay on 507 instead of 506?
Posted by: pspad | Date: 2021-04-13 12:27 | IP: IP Logged
5.0.6 is last stable version
5.0.7 are developer builds of next version
Posted by: Andreas | Date: 2021-04-13 14:28 | IP: IP Logged
Oh yes, sorry. I think I got confused about a visitor's tip.
Quote:Just a minor point, the subject still says 5.0.6 even though this is 5.0.7.
All good.
Posted by: brolx | Date: 2021-04-19 13:09 | IP: IP Logged
tabs colors regularly change to blank. Rezising window solves the problem (refresh)
