You are here: PSPad forum > Bug report / Hlášení chyb > strange 俰 character after the last update
Posted by: poopiepoop | Date: 2021-04-07 20:33 | IP: IP Logged
hello,
i am sorry for such a poor bug report but i really don't know how to reproduce it :(
after the latest update occasionally when editing a file, the pspad saves this strange sequene of characters
俰
this has happened about 3 times so far. the original encoding of all of my files is utf-8
i have also noticed that this happens when copypasting pieces of code that have ({}) characters in them and i sometimes miss a bracket. when my compiler shows me that a weird 俰 character appeared and i go highlight it, it shows that i have highlighted something else/brackets instead of those weird characters and the cursor is in a slightly shifted place too
Edited 2 time(s). Last edit at 2021-04-07 20:34 by poopiepoop.
Posted by: pspad | Date: 2021-04-08 05:32 | IP: IP Logged
Thank you for report. I will test it
Posted by: bluezero | Date: 2021-04-20 14:46 | IP: IP Logged
I have the same problem, 506 and 507 versions have it.
Was working fine before. But i remember having this problem few years ago too.
It appears to be always the ending curly bracket }
Edited 1 time(s). Last edit at 2021-04-20 14:46 by bluezero.
Posted by: Mog | Date: 2021-04-29 06:11 | IP: IP Logged
I have also had this problem. It seems to be connected with running text diff.
Forgot: Running latest version 5.0.6 64b.
Edited 1 time(s). Last edit at 2021-04-29 06:13 by Mog.
Posted by: keen | Date: 2021-05-02 12:54 | IP: IP Logged
I have the same problem!
It is very unpleasant. After a little modification of the source code, part of the website stopped working for me. It took me several hours to find out what happened and why. It never occurred to me that PSPad would rewrite part of the source code to Chinese characters on its own!
Posted by: pspad | Date: 2021-05-02 13:42 | IP: IP Logged
Test please current developer build
Posted by: bluezero | Date: 2021-05-03 15:42 | IP: IP Logged
5.0.7 (600)
Posted by: pspad | Date: 2021-05-03 16:13 | IP: IP Logged
Current developer build is 620, not 600
Posted by: bluezero | Date: 2021-05-06 12:25 | IP: IP Logged
Appeared in 623 again:
Posted by: pspad | Date: 2021-05-06 12:41 | IP: IP Logged
To find problem I need more information than screenshot.
I need as much information what what was done before it as possible
