You are here: PSPad forum > Bug report / Hlášení chyb > Re: PSPad destroys occasionally lines of source file
Goto Page: Previous1 2 3
#21 Re: PSPad destroys occasionally lines of source file
Posted by: pspad | Date: 2021-11-17 13:28 | IP: IP Logged
Simple replace binnaries, enough is pspad.exe + 2 openssl dll's
#22 Re: PSPad destroys occasionally lines of source file
Posted by: LouCypher | Date: 2021-11-17 14:09 | IP: IP Logged
Ok, I copied all different or missing files which were the finnish translation, the 2 executables in the Updater folder and in the root folder the different "PSPad.exe" and "WebView2Loader.dll" and the two 32 bit versions of the crypto dlls where the file name is different. I'm going to post back as soon as I see this problem with the 32 bit version as well and if not you might have an idea in which direction to look.
#23 Re: PSPad destroys occasionally lines of source file
Posted by: LouCypher | Date: 2022-01-25 12:47 | IP: IP Logged
As promised I'm giving here the short information that the problem also occurs with the 32 bit build of the current version 5.0.7.(727).
