You are here: PSPad forum > Bug report / Hlášení chyb > SHIFT+CTRL+N does not return to Normal Selection
#1 SHIFT+CTRL+N does not return to Normal Selection
Posted by: chip@onekid.net | Date: 2021-03-10 16:31 | IP: IP Logged
After using ALT key to select column mode and deleting some text:
1) Column selection mode persists
2) Using SHIFT+CTRL+N does not return to Normal Selection
I do have SHIFT+CTRL+N assigned to Normal Selection in editor preferences.
I am using 5.0.4 (543) 32 bit.
#2 Re: SHIFT+CTRL+N does not return to Normal Selection
Posted by: pspad | Date: 2021-03-10 16:59 | IP: IP Logged
There will be conflict in shortcuts.
Open program settings / KeyMap
List down for New File and delete shortcut Shift+Ctrl+N
