You are here: PSPad forum > Bug report / Hlášení chyb > Re: Escape Character Causes bracket matching Error in Visual LISP syntax
#1 Escape Character Causes bracket matching Error in Visual LISP syntax
Posted by: pkenewell | Date: 2020-10-20 20:10 | IP: IP Logged
Reporting a bug. The reverse quote (`) escape character is acting like the ending quote on a string and causing the matching bracket highlight to be incorrect. I am using the Visual LISP syntax file, but I don't know whether this bug is present with other code formats. This escape character from what I know should not be treated as a string in any code. Could you please look into this.
Thanks!
Edited 1 time(s). Last edit at 2020-10-20 20:12 by pkenewell.
#2 Re: Escape Character Causes bracket matching Error in Visual LISP syntax
Posted by: pkenewell | Date: 2020-10-20 20:41 | IP: IP Logged
P.S. I am using pspad version 5.0.3
#3 Re: Escape Character Causes bracket matching Error in Visual LISP syntax
Posted by: pspad | Date: 2020-10-20 23:06 | IP: IP Logged
Plrase write some Lisp code example.
Can you confirm it with current 5.0.4 build? I made lot of fixes there
Edited 1 time(s). Last edit at 2020-10-20 23:10 by pspad.
#4 Re: Escape Character Causes bracket matching Error in Visual LISP syntax
Posted by: pkenewell | Date: 2020-10-21 20:46 | IP: IP Logged
Here is a simple piece of code that will fail bracket matching
(wcmatch (strcase tx5) "*`.DGN")
The "`" character causes it.
I haven't tried 5.0.4 yet. I will give it a try and let you know.
Edited 1 time(s). Last edit at 2020-10-21 20:47 by pkenewell.
#5 Re: Escape Character Causes bracket matching Error in Visual LISP syntax
Posted by: pkenewell | Date: 2020-10-21 20:53 | IP: IP Logged
The 5.0.4 build of PSPad fixes the problem! Thanks!
