You are here: PSPad forum > Bug report / Hlášení chyb > Pspad 5.03 crash on Windows 8
#1 Pspad 5.03 crash on Windows 8
Posted by: marjuanm | Date: 2020-07-23 15:35 | IP: IP Logged
Greetings to all:
I don't know if this error was reported before, I searched the forum and although I see references to MSONSEXT.DLL I don't see a detailed description of the error that occurs to me.
I am using a Windows 8 computer, I still receive regular updates, so I keep my computer updated. While working with Pspad on this computer every time I get an error "Pspad stopped responding" and the program closes immediately, I see no way to report the error, the only option is to go to the Windows event viewer and I see this problem (image that I attach), I think Pspad gives an error with the library MSONSEXT.DLL. Thanks greetings.
#2 Re: Pspad 5.03 crash on Windows 8
Posted by: pspad | Date: 2020-07-23 16:26 | IP: IP Logged
Visit PSpad developer forum, download the current 5.0.4 build, unpack and replace existing files
#3 Re: Pspad 5.03 crash on Windows 8
Posted by: marjuanm | Date: 2020-07-24 02:49 | IP: IP Logged
thanks, but not is unstable yet?
#4 Re: Pspad 5.03 crash on Windows 8
Posted by: pspad | Date: 2020-07-24 03:45 | IP: IP Logged
It's continuously developed and when changes is more, it's published as full version.
If you backup your folder,you can simply return back previous version
Edited 1 time(s). Last edit at 2020-07-24 03:46 by pspad.
