You are here: PSPad forum > Bug report / Hlášení chyb > XML reformat - pspad stuck
#1 XML reformat - pspad stuck
Posted by: TonyWid | Date: 2020-07-29 12:27 | IP: IP Logged
version 5.0.3 32b
input was
<v1:testgeneral>
<v11:txtField01 />
<v11:txtField02 />
<v11:txtField03 />
<v11:txtField04 />
<v11:txtField05 />
<v11:txtField06 />
<v11:txtField07 />
<v11:txtField08 />
<v11:txtField09 />
</v1:testgeneral>
"stucks" means:
the editor pane with the xml input is shown empty and with no cursor.
you can open another editor pane (create new file) but you get no cursor and no ruler is displayed.
you can only close the program (dialog "do you want to save ..." is shown)
see also previous post
forum.pspad.com
#2 Re: XML reformat - pspad stuck - works after reinstall
Posted by: TonyWid | Date: 2020-07-31 08:41 | IP: IP Logged
thanks for your effort!
it was the portable version.
i "reinstalled" (unzipped) pspad and it works now.
(i should have tried this before reporting. sorry.)
