You are here: PSPad forum > Bug report / Hlášení chyb > Search and Copy with regular expression
Posted by: kuwowi | Date: 2020-07-11 13:42 | IP: IP Logged
when using copy-button in a search with regular expression i get the expression found only, not the whole line. Is this a bug or a feature?
There is a workaround: to use list-button and open result in a new document. But this has the disadvantage, that i cant deselect the line numbers in this case. Is this a bug too?
Posted by: pspad | Date: 2020-07-11 13:51 | IP: IP Logged
This is intentional. If you need whole line, add.* before and after expression to include whole line
