You are here: PSPad forum > Bug report / Hlášení chyb > Re: Incorrect highlighters
#1 Incorrect highlighters
Posted by: Zmy | Date: 2020-02-20 11:46 | IP: IP Logged
Hello.
Incorrect color detection for Hexadecimal.
#2 Re: Incorrect highlighters
Posted by: pspad | Date: 2020-02-20 11:54 | IP: IP Logged
$e is correct hexadecimal number
$v isn't hexadecimal number, in this case the $ means symbol char.
What I can do is remove symbol highlighting for the '$' char
#3 Re: Incorrect highlighters
Posted by: Zmy | Date: 2020-02-20 13:26 | IP: IP Logged
Yes, that would be great. Thanks.
#4 Re: Incorrect highlighters
Posted by: pspad | Date: 2020-02-21 14:32 | IP: IP Logged
I added variable attribute and modified user highlighter settings.
In the new build will it appear like this:
