You are here: PSPad forum > Bug report / Hlášení chyb > System integration still not working for restricted user
#1 System integration still not working for restricted user
Posted by: bolfh | Date: 2020-02-03 15:51 | IP: IP Logged
with version 5.0.2, it still doesn't seem to be possible to enable context menu integration for a restricted user after installing PsPad as asmin.
Steps to reproduce:
* Install PsPad as admin for all users
* Enable Context Menu entries (still admin)
* Switch to restricted (non-admin user)
Result:
* The restricted user has no context menu entry for PsPad.
* The restricted user can't check "Register in System context menu" because the check box is greyed out.
Tried different approaces, DLL or registry, no success.
New Windos 10 1909 machine, but was the same on my own 1903 PC several months ago.
Oliver
#2 Re: System integration still not working for restricted user
Posted by: pspad | Date: 2020-02-03 17:23 | IP: IP Logged
I will try to simulate it.
You can try next:
start cmd as admin
move to PSpad folder
run command (which one depends of your system):
regsvr32 pspadshellx64.dll
or
regsvr32 pspadshellx32.dll
for unregistering e.g.:
regsvr32 -u pspadshellx64.dll /u
#3 Re: System integration still not working for restricted user
Posted by: pspad | Date: 2020-02-03 17:32 | IP: IP Logged
I found there is some problem in configuration - enabling of the checkboxes.
I will fix it and check under restricted user.
#4 Re: System integration still not working for restricted user
Posted by: bolfh | Date: 2020-02-03 19:04 | IP: IP Logged
great, thanks!
I'll return to the affected PC in a few days and try your suggestions (unless you have other news till then).
Greetings
Oliver
#5 Re: System integration still not working for restricted user
Posted by: pspad | Date: 2020-02-04 13:46 | IP: IP Logged
I hope it's fixed.
I just tested whole proces - I created new limited profile, installed PSPad into program files. After installation there were no entries in context menu.
But I was able to use PSpad program settings and check the option in system integration tab as normal limited user. After it PSPad items appeared in context menu.
#6 Re: System integration still not working for restricted user
Posted by: bolfh | Date: 2020-02-06 21:02 | IP: IP Logged
great. Will it be published as a developer version?
#7 Re: System integration still not working for restricted user
Posted by: pspad | Date: 2020-02-07 04:16 | IP: IP Logged
I hope this weekend
#8 Re: System integration still not working for restricted user
Posted by: bolfh | Date: 2020-02-14 06:41 | IP: IP Logged
works now, many thanks!
Greetings,
Oliver
