You are here: PSPad forum > Bug report / Hlášení chyb > Re: PSPAD entry has disappeared from the context menu
#1 PSPAD entry has disappeared from the context menu
Posted by: RANZI | Date: 2020-01-02 08:26 | IP: IP Logged
With version 5.0.1, I had 3 entry in context menu :
- PSPad
- PSPad HEX
- PSPad Diff
After update to 5.0.2, I have only :
- PSPad HEX
- PSPad Textdiff
After to switch with DLL and Register option, the 3 entry has reapperared.
Strange ...
#2 Re: PSPAD entry has disappeared from the context menu
Posted by: pspad | Date: 2020-01-02 08:32 | IP: IP Logged
DLL is better solution than registry.
And I agree, it's strange. But easily to fix - uncheck in program settings / Integration, apply, check and apply again.
