You are here: PSPad forum > Bug report / Hlášení chyb > Not Working aTagToUpperCase
#1 Not Working aTagToUpperCase
Posted by: Zmy | Date: 2020-01-03 02:40 | IP: IP Logged
Hello, Jan.
When I have a Russian keyboard layout,
then the commands from the "Format\Char Case Change" menu do not work.
With English work, but with Russian there is no.
PSPad 32(bit) 5.0.3 (355).
#2 Re: Not Working aTagToUpperCase
Posted by: pspad | Date: 2020-01-03 06:12 | IP: IP Logged
I can confirm that Char case change doesn't work with cyrilic letters.
Tag to upper case or tag to lover case works with TAGs only, it's subset of Code case change function from menu format.
I will try to find a reason.
#3 Re: Not Working aTagToUpperCase
Posted by: pspad | Date: 2020-01-03 06:37 | IP: IP Logged
Reason found and fixed in whole editor code.
#4 Re: Not Working aTagToUpperCase
Posted by: Zmy | Date: 2020-01-03 10:58 | IP: IP Logged
OK, Thanks.
