You are here: PSPad forum > Bug report / Hlášení chyb > Re: Bug + fix - AutoHotkey auto syntax detection
Posted by: DuckDaffy | Date: 2016-05-09 07:28 | IP: IP Logged
Due wrong syntax*.ahk*
in these files:
AutoHotkey.DEF
(4x)
AutoHotkey.INI
(1x)
PSPad cannot autodetect right syntax profile and you must everytime select syntax manually.
Fix: change all*.ahk*
to*.ahk
(remove last star char) in files above.
Posted by: pspad | Date: 2016-05-09 08:41 | IP: IP Logged
I will do it. But as I remember, Autohotkey uses .ahk2 extension too, so I will extend it
Posted by: DuckDaffy | Date: 2016-05-09 10:43 | IP: IP Logged
Thx for confirmation.
As I see, also *.ah2 extension is exist.
www.autohotkey.com
Edited 1 time(s). Last edit at 2016-05-09 10:46 by DuckDaffy.
Posted by: DuckDaffy | Date: 2016-05-09 10:50 | IP: IP Logged
And as I see there are a lot of changes in AutoHotkey v2 so will be better to create a new DEF file for v2.
What you mean?
Posted by: pspad | Date: 2016-05-09 11:08 | IP: IP Logged
DuckDaffy:And as I see there are a lot of changes in AutoHotkey v2 so will be better to create a new DEF file for v2.
What you mean?
Are you able to prepare it? I am not Autohotkey user.
In the fact, you need list of keywords only and put it into menu Settings / User highlighter
Posted by: DuckDaffy | Date: 2016-05-09 12:18 | IP: IP Logged
pspad:DuckDaffy:And as I see there are a lot of changes in AutoHotkey v2 so will be better to create a new DEF file for v2.
What you mean?Are you able to prepare it? I am not Autohotkey user.
Sorry, I'm afraid that I can't help you.
I'm only hobby AutoHotkey v1 user and I haven't skill (and time) to completly collect and verify all AHK keywords and encourage other changes in AHK v2.
Hope some another handy user will do it. ;)
