You are here: PSPad forum > Bug report / Hlášení chyb > Re: ascii table columns too narrow
#1 ascii table columns too narrow
Posted by: glennman | Date: 2015-01-09 10:38 | IP: IP Logged
The columns in the Ascii Table Tool are too narrow.
Cannot see the entire values.
Cannot change the column widths.
Changing the size of the left window does not change the Ascii table column widths.
Using version 4.5.8 in Windows 7 Pro.
#2 Re: ascii table columns too narrow
Posted by: pspad | Date: 2015-01-09 12:11 | IP: IP Logged
It looks like you use higher DPI in your system. Download current developer build 459 from developer forum. Problems with higher DPI are solved in this build.
