You are here: PSPad forum > English discussion forum > Re: Hopefully a simple settings change?
Posted by: groston | Date: 2023-12-11 20:43 | IP: IP Logged
For reasons that I do not understand, I had to uninstall and reinstall PSPad. Not the end of the world, but I have had to reestablish all of my settings. One that I cannot figure out is this: I have enabled Word Wrap lines, but now the wrapped-line indicator is highlighted in green. Is there some way to turn off this highlighting?
Posted by: pspad | Date: 2023-12-11 21:42 | IP: IP Logged
Can you provide a screenshot? Line numbers are green too?
Posted by: groston | Date: 2023-12-12 17:57 | IP: IP Logged
The image shows the issue (circled in red). I am also wondering if it is possible to hide the bar that shows changes (also circled in red).
Posted by: pspad | Date: 2023-12-13 06:24 | IP: IP Logged
You are right with the wrap sign. I didn't noticed it. I will change it to left bar color.
Related to line change indicator, open program settings, go to Code folding page and set with of the line change indicator to 0.
Posted by: groston | Date: 2023-12-13 20:34 | IP: IP Logged
Thank you for the prompt reply and indicating the change you would make. However, I cannot change the setting you indicated, because I do not see it. Note that I am running PSPad V5.0.7 (775).
Posted by: pspad | Date: 2023-12-13 21:05 | IP: IP Logged
Download the current 32b version from PSPad developer forum and replace content of existing folder
Posted by: groston | Date: 2023-12-13 23:47 | IP: IP Logged
I downloaded from here, www.pspad.com, uninstalled then reinstalled, but nothing. I am guessing I downloaded the wrong file...
Posted by: pspad | Date: 2023-12-14 05:23 | IP: IP Logged
Dont uninstall, unpack and replace files
Posted by: groston | Date: 2023-12-14 16:52 | IP: IP Logged
Thank you - that worked and issue resolved
