You are here: PSPad forum > English discussion forum > Re: PSPad + golang
Posted by: AskMe | Date: 2023-02-18 14:31 | IP: IP Logged
I started learning Go (aka golang),
and use LiteIDE to write programs, but that editor is not as good for me as PSPad,
but in PSPad there is no such programming language as Go.
Can we hope to replenish PSPad with a new language?
Posted by: pspad | Date: 2023-02-18 14:36 | IP: IP Logged
Google Go is supported as user definition. Open menu Settings / Highlighter settings
Scroll down for any free position for user highlighter and on the second tab select Google go. Confirm it and PSPad knows Go.
Posted by: AskMe | Date: 2023-02-18 15:41 | IP: IP Logged
Yes, PSPad knows Go! the backlight is on!
But, Settings -> Highlighters Settings:
"C:\Program Files\Go\bin\go.exe build" "%File%"
and press F9, but the program does not start:
(c:/Program Files/Go/bin/go.exe build hello.go)
and there is no assembly either:
(c:/Program Files/Go/bin/go.exe run hello.go)
It seems that I did not do everything correctly to start the program?
Posted by: AskMe | Date: 2023-02-18 16:27 | IP: IP Logged
Everything worked!
It should have been written like this:
"c:\Program Files\Go\bin\go.exe" "run" "%File%"
Thank you very much for the help!
PSPad great editor!
