You are here: PSPad forum > English discussion forum > Code overview
Posted by: halweg | Date: 2022-02-24 11:43 | IP: IP Logged
1. I like the code explorer window to get orientation in my code segments.
Unfortunately in Autohotkey the code explorer shows only labels like a: or doesn't show Hotkey-Labels like
UP:: or ^#g::
Is this by design or do I miss any setting?
2. I use comment lines like
; ======================== Title ==================
to get an overview when scrolling my code.
It would be great, to see such lines in the code explorer (or some other permanent sub-window). Is this possible? Which settings should I modify?
3. Alternatively I can set a bookmark in every ;===== line.
Is it possible to get an overview about the bookmarks the same way like the code explorer?
The existing bookmark list is fine but I can't navigate in this list and it steals me the focus from the main window.
Posted by: pspad | Date: 2022-02-24 11:52 | IP: IP Logged
1. Code labels
there is no problem to modify code parser, but please don't suppose I am worlking with all supported languages. Users are the ones who initiates change.
Can you send me please some more complex AutoHotkey code sample?
In the Highlighter settings is possibility to set Document comment, what is displayed in the Code explorer. Put there e.g.: ; ===
3. Bookmark overview is available as the bookmark list (Menu Search). But not as docked window
Posted by: halweg | Date: 2022-02-24 16:31 | IP: IP Logged
Thanks again!
pspad:1. Code labels
Labels and functions work fine:
function_name(param1,param2)
codeline1
codeline2
(This works for the code explorer)
label1:codeline
label2:
codeline1
codeline2
(labels with : works for the code explorer)
RETURN
The problem is with the hotkey labels, s. 1drv.ms
In this code example the hotkeys F13:: an APPSKEY:: are shown in the code explorer but not the others, like #ä::
pspad:2. I use comment lines like
Thanks. This is a good functionality and it works now. But as visible in the image I need to change the === lines a little bit for more overview.
Posted by: pspad | Date: 2022-03-17 13:02 | IP: IP Logged
Shortcut labels are fixed. Available in the next build
Posted by: halweg | Date: 2022-05-24 15:36 | IP: IP Logged
I just downloaded build 731. Hotkey Labels like #t are now visible in the code explorer. Thanks!
But in Autohotkey there are much more kinds of labels possible.
See www.autohotkey.com .
Moreover there are "Hotstrings", see www.autohotkey.com .
Its quite similar.
The simplified rule, as fare I understood, is:
Everything before the last :: (outside quotes) in a line is a Hotstring or a Hotkey Label.
Labels may occur separately on a line or directly before a single line command.
hotkey examples:
^t:: any command
^#+!F4::
Alt & /::
*APPSKEY UP::any command
hotstring examples:
::btw::by the way
:*:j@::
:?:</em>::
:*?:please replace::Please replace
The proper representation of labels in the code explorer isn't the most important think, but having it would be nice.
