You are here: PSPad forum > English discussion forum > Re: Feature Request - Open Containing Folder in Windows Explorer
#1 Feature Request - Open Containing Folder in Windows Explorer
Posted by: PGomersall | Date: 2021-12-04 21:38 | IP: IP Logged
Jan,
I would like you to consider adding a right click context item to a tab - "Open Containing Folder in Windows Explorer". Basically the feature that is under discussion here: forum.pspad.com
Obviously, there are work arounds as described but not as convenient.
Regards,
Pete
#2 Re: Feature Request - Open Containing Folder in Windows Explorer
Posted by: pspad | Date: 2021-12-04 22:21 | IP: IP Logged
This is no problem
#3 Re: Feature Request - Open Containing Folder in Windows Explorer
Posted by: PGomersall | Date: 2021-12-06 01:42 | IP: IP Logged
Thank you for adding it to 717 - wonderful!
Regards,
Pete
