You are here: PSPad forum > English discussion forum > Missing deps @me // Problem w/ 5.0.6(589) // WinXP
#1 Missing deps @me // Problem w/ 5.0.6(589) // WinXP
Posted by: Christo P. Christoff | Date: 2021-09-20 10:22 | IP: IP Logged
Hi!
I can not open the 32bit portable after 5.0.6(589).
The message is:
'PSPad.exe is not a valid Win32 application.'.
I also noticed missing dll's
DWMAPI.DLL
SHCORE.DLL
My Windows is old.
I really love your work.
But should I really upgrade the OS?
Best regards
Chris
Edited 1 time(s). Last edit at 2021-09-22 06:23 by Stefan.
#2 Re: Missing deps @me
Posted by: pspad | Date: 2021-09-20 10:27 | IP: IP Logged
Build 581 was compiled under new Delphi version and there is minimal version set higher than your Windows XP.
Next build should work under Windows XP again.
