You are here: PSPad forum > English discussion forum > How to make multi-instance default
#1 How to make multi-instance default
Posted by: AshantiMckay | Date: 2021-09-14 23:09 | IP: IP Logged
I found in settings /system integration that there is an option checked , only one program instance. But that option seems not allowed to be disabled.
I need that, for every launch of the program, a new independent windows comes up, and I'm aware of the /n command line option, but it is not useful in this situation.
Is there an option to make multi-instance default? If so, which is the file that should be changed and how?
Thanks!
#2 Re: How to make multi-instance default
Posted by: pspad | Date: 2021-09-15 03:16 | IP: IP Logged
Run pspad as admin, some marked iptions requires it
