You are here: PSPad forum > English discussion forum > Feature request: Keep tabs (of documents) sorted
#1 Feature request: Keep tabs (of documents) sorted
Posted by: rovf | Date: 2021-09-03 07:12 | IP: IP Logged
Could we have a setting, which, when turned on, keeps the tabs sorted according to the filenames?
In particular when many tabs are open (in my case, often 30-40 files), it is sometimes tedious to locate a particular one.
The project panel which also shows all open files (sorted) is already a great help, but I usually display there my project view.
Ronald Fischer (Germany)
Edited 1 time(s). Last edit at 2021-09-10 09:18 by Stefan.
#2 Re: Feature request: Keep tabs sorted
Posted by: pspad | Date: 2021-09-03 07:58 | IP: IP Logged
next to the project tab is open files tab, what can help you too.
#3 Re: Feature request: Keep tabs sorted
Posted by: rovf | Date: 2021-09-10 13:02 | IP: IP Logged
I know. As I wrote in my posting, this is what I use in the meantime. However, since I want to see the (really useful) project tab too, this requires me to switch often between project tab and open file tab. Having the tabs sorted, would allow me to keep the project tab open all the time.
