You are here: PSPad forum > English discussion forum > Feature Request
Feature Request
#1 Feature Request
Posted by: m227 | Date: 2021-06-11 14:34 | IP: IP Logged
I use PSPad for many years. One of mostly used feature is searching in files.
I'd like to have possibility to exclude some masks instead of include ones.
For example to be able to write:
Quote:
-*.exe
to search all file types except exe ones.
#2 Re: Feature Request
Posted by: pspad | Date: 2021-06-11 16:02 | IP: IP Logged
Open Program settings / Files and dirs
add .exe into ignore files list
#3 Re: Feature Request
Posted by: bruste | Date: 2026-08-24 08:35 | IP: IP Logged
Tried this configuration in "Ignore files"
.cvsignore;vssver.scc;.git;.svn;.exe
but .exe files are scanned for the same
tested with version 5.5.3 (857)
#4 Re: Feature Request
Posted by: pspad | Date: 2026-08-24 09:13 | IP: IP Logged
bruste:
Put there *.exe.
.cvsignore is full file name, .exe isn't
#5 Re: Feature Request
Posted by: bruste | Date: 2026-08-24 10:25 | IP: IP Logged
Tried with
.cvsignore;vssver.scc;.git;.svn;*.exe
But .exe files are parsed anyway
#6 Re: Feature Request
Posted by: pspad | Date: 2026-08-24 11:15 | IP: IP Logged
bruste:
Tried with
I have to confirm, if there are the wildchars evaluated.
If you have few exes only, you can list there their full names as temporary workarround
#7 Re: Feature Request
Posted by: pspad | Date: 2026-08-25 08:55 | IP: IP Logged
bruste:
Tried with
Done. Will be available in the future build
