You are here: PSPad forum > English discussion forum > How to reverse the numbers [Reverse String]?
#1 How to reverse the numbers [Reverse String]?
Posted by: Haunebu | Date: 2021-05-31 11:01 | IP: IP Logged
How to reverse the numbers [Reverse String] in a simple way?
The numbers are located separately on the line.
Example:
23
65
79
91
Result:
32
56
97
19
Edited 1 time(s). Last edit at 2021-05-31 11:07 by Haunebu.
#2 Re: How to reverse the numbers [Reverse String]?
Posted by: pspad | Date: 2021-05-31 11:16 | IP: IP Logged
You have script what calculates your numbers.
Modify it to reverse lines.
#3 Re: How to reverse the numbers [Reverse String]?
Posted by: Haunebu | Date: 2021-05-31 11:47 | IP: IP Logged
It kind of works with the input window but only for one string, it needs to be tweaked, modified but no further ideas.
ReverseString.vbs
File:
www97.zippyshare.com
