You are here: PSPad forum > English discussion forum > Re: Strange characters insertion
Posted by: bluezero | Date: 2021-06-14 19:02 | IP: IP Logged
Still happening in build 651.
On 3 places at once (probably) in a file of 6340 lines.
While its not fixed, could you add the same character check on switching tabs, so I don't save corrupted files.
Posted by: pspad | Date: 2021-06-14 19:25 | IP: IP Logged
How often does it happen in compare to previous build(s)?
Really is enough to switch file or you close some file?
Edited 1 time(s). Last edit at 2021-06-14 19:28 by pspad.
Posted by: bluezero | Date: 2021-06-14 21:00 | IP: IP Logged
Subjectively: In the last two builds seem to be less.
I would say that for me it happens only on switching tabs, although i may be wrong, its hard to notice. One notices it when things stop to work .
Posted by: bluezero | Date: 2021-06-16 19:54 | IP: IP Logged
Happened to me today and yesterday too. So it is still pretty frequent.
Posted by: pspad | Date: 2021-06-17 04:58 | IP: IP Logged
I am still investigating it.
It started with Delphi 10.3 version.
I use shared highlighters, it means all files of same type, e.g. PHP uses one shared hihglighter object.
I will rewrite it and create for each file individual highlighter.
It will be lot of work - color handlings, multihighlighter is several highlighters joined into one.
So please be patient, I don't give it up.
Posted by: bluezero | Date: 2021-06-17 07:29 | IP: IP Logged
Could you add the character check after switching tab in the meanwhile?
Maybe just as a hidden feature, that can be enabled through the config file or something like that.
Posted by: bluezero | Date: 2021-06-21 14:27 | IP: IP Logged
655 - still happening
Posted by: pspad | Date: 2021-06-21 14:51 | IP: IP Logged
bluezero:655 - still happening
Frequency? More, less or sane?
Posted by: bluezero | Date: 2021-06-21 16:45 | IP: IP Logged
Only once today so far. Didnt "work" on the weekend .
I will repeat my request:
Posted by: bluezero | Date: 2021-06-23 13:18 | IP: IP Logged
Happened today again. It was after a crash when closing another file. Not sure if related thou.
