You are here: PSPad forum > English discussion forum > Re: About search in files
Posted by: compos | Date: 2021-04-29 06:25 | IP: IP Logged
Is any possibility to perform "Search/replace in files ..." without specification type of file coding (ANSI, UTF and so on)?
Unfortunately I have project with two types of file coding and obliged each time to do 2 searching with each coding type.
Posted by: pspad | Date: 2021-04-29 16:09 | IP: IP Logged
Hello.
I suggest you to select any ANSI encoding, cause PSpad is able (and do it) to detect UTF-8 and UTF-16 encodings.
Without encoding there is problem find anything, UTF-8 uses 1-3 bytes for char, UTF-16 uses 2 bytes for char, how do you imagene PSpad will look for string?
