You are here: PSPad forum > English discussion forum > 5.0.6 - only today 6 crashes
Posted by: compos | Date: 2021-04-04 18:11 | IP: IP Logged
64-bit and Windows-10.
Version 5.0.6 - only today 6 crashes of PSPAD. May be to roll back this version?
Alex
Posted by: pspad | Date: 2021-04-04 18:14 | IP: IP Logged
Hello. If you want to help, send me exception reports + description what leads to exception. Without it your add is useless and doesn't help to anybody
Posted by: johntrot | Date: 2021-04-28 16:13 | IP: IP Logged
I have this problem multiple times in any session... appears to be worse in this 506 version...
Pspad crashes with no apparent reason...
I have mailed this and other craches many times over the past year.
Hope this helps!!!
Exception class:
Exception address:
Stack list, generated 21/04/28 10:08:57 AM
Thank you for your time to report this issue!
Please don't post exception report into the forum.
Send it to my support address (see Help > About).
And please add a short description what you did when exception occurred,
e.g.: close file (generic advice, nothing special to you)
In some cases I am else not able to recognize what caused exception.
- What did you do: ....<accurate step-by-step instructions here>..
- How did you do: by keyboard press, by menu, context menu, macro
- You had expected to get: ....
- But you got instead: .....
Thank you.
Program : C:\Program Files\PSPad editor\PSPad.exe 5.0.6 (589)
System : Windows 10 Home Edition x64, Version: 10.0, Build: 4A61,
Processor: Intel, Intel(R) Core(TM) i5-5200U CPU @ 2.20GHz, 2200 MHz MMX
Display : 1600x900 pixels, 32 bpp PPI: 120
Skin : Windows
Active Controls Hierarchy:
TPSSynEdit ""
TfChildEdit ""
Edited 1 time(s). Last edit at 2021-04-29 06:37 by Stefan.
Posted by: johntrot | Date: 2021-04-28 20:05 | IP: IP Logged
just had this failure
vs 506
doing nothing but reviewing a file
Exception class:
Exception address:
Stack list, generated 21/04/28 2:02:59 PM
Thank you.
Skin : Windows
TPSSynEdit ""
TfChildEdit ""
