You are here: PSPad forum > English discussion forum > Re: Tool Panel - "Edit Link" Dialogue - Proposal
Posted by: tmpad | Date: 2021-02-10 19:59 | IP: IP Logged
In the "Edit Link" dialogue in the "Tool Panel" the usage of context menus (Right Mouse Button) is not consistent:
* The fields "Parameters" and "Log File" have a context menu with PSPad variables
* The field "Default Directory" has the standard Windows context menu for entry fields with Cut, Copy, Paste etc. Variables have to be edited manually or copied from one of the other fields.
Proposal:
* use the standard Windows context menu for all three fields
* each field gets an additional button, similar to the [?] buttons in the "Replace" dialogue, that opens the menu with PSPad variables
Posted by: pspad | Date: 2021-02-13 20:38 | IP: IP Logged
I consider it as good proposal. Dialog was modified - new buttons was added to each edit.
