You are here: PSPad forum > English discussion forum > Re: Find/Replace Regular Expression limit
Posted by: garbuya | Date: 2021-01-07 19:33 | IP: IP Logged
PSPad ver 5.04 but in About it still shows 5.03 (bug!!!), Win 10 x64
This is an example
SELECT 1 from dual where 1=1 and 9=9;
SELECT 2 from dual where 2=2 and 8=8;
SELECT 3 from dual where 3=3 and 7=7;
SELECT 4 from dual where 4=4 and 6=6;
SELECT 5 from dual where 5=5 and 5=5;
SELECT 6 from dual where 6=6 and 4=4;
SELECT 7 from dual where 7=7 and 3=3;
SELECT 8 from dual where 8=8 and 2=2;
SELECT 9 from dual where 9=9 and 1=1;
I want to split lines so WHERE will be on next line
So Ctrl+H, checked "Regular Expressions" and "Entire Scope"
Find: (.*)( )(where)(.*)
Replace: $1\n$3$4
As a result only 5 lines are split? Why?
How to bypass this limitation?
Increasing Max Undo to max number 20000 did not help.
If UNDO is a show stopper how to disable UNDO at all?
SELECT 1 from dual
where 1=1 and 9=9;
SELECT 2 from dual
where 2=2 and 8=8;
SELECT 3 from dual
where 3=3 and 7=7;
SELECT 4 from dual
where 4=4 and 6=6;
SELECT 5 from dual
where 5=5 and 5=5;
Edited 4 time(s). Last edit at 2021-01-07 19:40 by garbuya.
Posted by: pspad | Date: 2021-01-07 19:38 | IP: IP Logged
If PSPad in About shows you 5.0.3, it means you start other PSPad version that you installed.
Check if you don't copy PSpad instead of make shortcut e.t.c.
There is a problem when replace creates new lines. In this case is necessary to start from the end with backward direction.
Posted by: garbuya | Date: 2021-01-07 19:47 | IP: IP Logged
And this one does not work at all -- I want to split by WHERE and AND
Find: (.*)( )(where|and)(.*)
Replace: $1\n$3$4
Oops!
Still only 5 lines processed, but why WHERE stays on the same line?
and 9=9;
and 8=8;
and 7=7;
and 6=6;
and 5=5;
Posted by: garbuya | Date: 2021-01-07 19:50 | IP: IP Logged
I downloaded zip file
PSPad.exe size in zip is 10,811,888 (Jan 1, 2021)
The old PSPad.exe ver 5.03 has size 9,788,032 (Feb 10, 2020)
Posted by: pspad | Date: 2021-01-07 19:51 | IP: IP Logged
From where you downloaded ZIP file?
When you run directly PSPad.exe from the folder you unpacked ZIP, it shows you 5.0.3 in about dialog?
Posted by: pspad | Date: 2021-01-07 19:57 | IP: IP Logged
garbuya:And this one does not work at all -- I want to split by WHERE and AND
Replace: $1\n$3$4
This is quite nonsense, cause you have "where OR and" in search and want to replace both at once
Edited 1 time(s). Last edit at 2021-01-07 19:57 by pspad.
Posted by: pspad | Date: 2021-01-07 20:11 | IP: IP Logged
Search: (.*)(where.*)(and.*)
Replace: $1\n$2\n$3
Direction: backward
or you can format output and add tabs before "where" and "and"
Replace: $1\n\t$2\n\t\t$3
Posted by: garbuya | Date: 2021-01-07 20:48 | IP: IP Logged
Downloaded pspad504en.zip from this site
Help->About shows 5.03(377)
Posted by: pspad | Date: 2021-01-07 21:00 | IP: IP Logged
garbuya:Quote:From where you downloaded ZIP file?
When you run directly PSPad.exe from the folder you unpacked ZIP, it shows you 5.0.3 in about dialog?Downloaded pspad504en.zip from this site
Pspad504en.zip doesn't contains 5.0.3 version.
Run directly pspad.exe from the folder you unpacked zip
Posted by: garbuya | Date: 2021-01-08 16:36 | IP: IP Logged
Quote:This is quite nonsense, cause you have "where OR and" in search and want to replace both at once
This is just an example for demonstration.
What I'm trying to say is that PSPad when replaces with Regular Expressions takes only one action going from the right to left and it should process all
a b b c c b b d
Find: (.*)(b|c)(.*)
Replace: $1~$3
a b b c c b ~ d
As you can see only the rightmost occurrence is processed.
regexp_replace takes optional parameters position and occurrence
Quote:REGEXP_REPLACE( <subject> , <pattern> [ , <replacement> , <position> , <occurrence> , <parameters> ] )
If omitted, by default position = 1 and occurrence = 0 (all occurrences)
It looks like PSPad passing 1 to occurrence instead of 0
Please verify
Thank you
Edited 2 time(s). Last edit at 2021-01-08 16:45 by garbuya.
