You are here: PSPad forum > English discussion forum > Left panel - restore last active panel tab
Posted by: Professor Bernd | Date: 2020-10-19 00:10 | IP: IP Logged
Hello.
In the left panel there are different panel tabs: Project, File Explorer, FTP, Favorites, Open file list.
Could you please implement that the panel tab that is active when closing PSPad will be the active panel tab again the next time you open PSPad?
For example, if the Favorites tab is visible when closing PSPad, the Favorites tab should be visible again when starting PSPad.
Posted by: pspad | Date: 2020-10-19 05:41 | IP: IP Logged
There is a default shortcut to jump to favorite panel (Shift+Ctrl+X)
You can map it in Program settings / KeyMap / File
as OpenFavourite
Is available as the item in the File menu
Posted by: Professor Bernd | Date: 2020-10-19 06:20 | IP: IP Logged
Here is the same situation as in the other thread:
I know the shortcut, but it does not help. Then I and every other user have to press the shortcut every time after starting PSPad.
Can't you set it up so that when you start PSPad, it restores the state that the panel had when you closed PSPad?
If you don't set this up, the user won't be able to open a PSPad project without closing the left panel with a shortcut each time, and the user won't be able to start PSPad with the desired panel tab without pressing the corresponding shortcut each time.
