You are here: PSPad forum > English discussion forum > Re: Project - hide left panel permanently
#1 Project - hide left panel permanently
Posted by: Professor Bernd | Date: 2020-10-18 23:26 | IP: IP Logged
Example:
I create a project in PSPad and add e.g. 4 files. Then I save the project as "New project.ppr", close the left panel (tool panel) and then I close PSPad. When I open "New project.ppr" with PSPad afterwards, the left panel is shown again.
How can I make the left panel have the same visibility state when I start "New project.ppr" with PSPad as it had when I closed PSPad?
#2 Re: Project - hide left panel permanently
Posted by: pspad | Date: 2020-10-19 05:31 | IP: IP Logged
If project is loaded, left panel is intentionally visible.
Ctrl+F2 shows/hides it quickly
#3 Re: Project - hide left panel permanently
Posted by: Professor Bernd | Date: 2020-10-19 06:02 | IP: IP Logged
I know the shortcut, but it does not help. Then I and every other user have to press the shortcut every time after starting PSPad, again and again.
Can't you set it up so that when you start PSPad, it restores the state that the panel had when you closed PSPad?
