You are here: PSPad forum > English discussion forum > Basic how it works
Basic how it works
#1 Basic how it works
Posted by: UnConnoisseur | Date: 2020-09-02 11:04 | IP: IP Logged
No Help or Search, so basic question:
Correct? Bold - Build supported as released
Not Bold (1 2 3 ...) - Build UNsupported as unnreleased
* What does it mean when it starts over? (1 2 1 2 3 ...)
No?
No beta testing support?
Thanks.
-bc
#2 Re: Basic how it works
Posted by: pspad | Date: 2020-09-02 11:11 | IP: IP Logged
To be honest, I don't understand what do you mean.
I don't make difference between full release or developer builds regards to support.
I am answering question from all users.
If you use old version and there are problems, you will get answer update to current.
I am not able to fix few versions continuously together. If there is any problem, it will be fixed in next build.
#3 Re: Basic how it works
Posted by: pspad | Date: 2020-09-02 11:15 | IP: IP Logged
Your thread was moved into general discusion. Don't start new topics in the developer forum, because from topics in the developer forum RSS feed is generated.
Open any build, you can discuss there, ask question, offer new ideas, report bugs.
