You are here: PSPad forum > English discussion forum > no PHP highlight with large files
Posted by: PaulPic | Date: 2020-08-24 02:08 | IP: IP Logged
version 504b407x64 -- problem exists since quite a few versions back, not with older versions.
I have 2 files with more than 1 MB and a lot of functions to be parsed. When loading, the beginning of the file is shown with highlighting, when loading finished, highlighting is gone.
Activating highlighting works immediately.
Posted by: pspad | Date: 2020-08-24 04:45 | IP: IP Logged
Program settings / direct edit button
Change value of variable;
HLUpToSize=1500000
Value means size of bytes
Posted by: PaulPic | Date: 2021-05-22 22:40 | IP: IP Logged
Thank you, I just noticed this answer via forum.pspad.com searching for syntax highlighting.
Posted by: PaulPic | Date: 2021-05-22 22:46 | IP: IP Logged
I probably did not notice as you have to remember to check "Send replies to this thread to me via email" every time...
Wasn't a big deal for me as I made a hotkey with AHK which switches on highlighting and rearranges tabs in one go.
Posted by: pspad | Date: 2021-05-23 06:02 | IP: IP Logged
Forum notification is broken and I have no time to find and fix it
