You are here: PSPad forum > English discussion forum > Re: Install extensions
#1 Install extensions
Posted by: mne.webmaster | Date: 2020-07-20 20:49 | IP: IP Logged
Good evening, I don't understand how to install the extensions and under what menu item they are after installation. Thank you
Mne
#2 Re: Install extensions
Posted by: pspad | Date: 2020-07-21 05:29 | IP: IP Logged
1. You need to copy it into subfolder .\Script\xxxxx where xxxx is scripting language
2. You need to enable scripting support, if isn't enabled in the program settings / System integration
Extension has own method how to create menu item in the Scripts menu
#3 Re: Install extensions
Posted by: mne.webmaster | Date: 2020-07-21 10:16 | IP: IP Logged
Thank you
Mne
