You are here: PSPad forum > English discussion forum > Re: Import multiple files = always no response program
#1 Import multiple files = always no response program
Posted by: maki | Date: 2020-06-23 14:33 | IP: IP Logged
Cannot import multiple files, all files show "no response".
I downloaded many programs, tested them and all show no response ...
i want to merge txt, html etc.
10 000 + files (Total Size 500 MB)
Edited 1 time(s). Last edit at 2020-06-23 14:35 by maki.
#2 Re: Import multiple files = always no response program
Posted by: pspad | Date: 2020-06-23 14:47 | IP: IP Logged
I answered you how to make it with COPY command, when you asked last time.
#3 Re: Import multiple files = always no response program
Posted by: maki | Date: 2020-06-23 15:30 | IP: IP Logged
I know but the problem is that there are many other subfolders inside the folder. I do not know commands for subfolders.
copy * result.html (one folder)
* --> no extension
command incl. multifolders?
Edited 3 time(s). Last edit at 2020-06-23 15:33 by maki.
#4 Re: Import multiple files = always no response program
Posted by: pspad | Date: 2020-06-23 15:50 | IP: IP Logged
Put all files into one folder and as second step copy it into one file.
For first step use XCOPY command
#5 Re: Import multiple files = always no response program
Posted by: maki | Date: 2020-06-23 15:56 | IP: IP Logged
But I don't want to put thousands all in one folder. I want files to be in (SUB)folders.
What Command search/find for files in subfolders?
Edited 1 time(s). Last edit at 2020-06-23 15:57 by maki.
#6 Re: Import multiple files = always no response program
Posted by: pspad | Date: 2020-06-23 16:01 | IP: IP Logged
I offered you solution. You don't want it, so find any solution yourself.
Open 10 000+ files in text editor is nonsense.
It's not related to PSpad, I masked this thread as closed.
This Thread has been closed
