You are here: PSPad forum > English discussion forum > Re: Multi File Name Find
Goto Page: Previous1 2
#11 Re: Multi File Name Find
Posted by: maki | Date: 2020-05-31 16:55 | IP: IP Logged
The file created in a few seconds has a size
42.7 MB
The numbers are simply a winning system:
Example:
01 02 03 04 05 06 07
01 02 03 04 05 06 08
01 02 03 04 05 06 09
01 02 03 04 05 06 10
01 02 03 04 05 06 11
01 02 03 04 05 06 12
01 02 03 04 05 06 13
01 02 03 04 05 06 14
01 02 03 04 05 06 15
01 02 03 04 05 06 16
01 02 03 04 05 06 17
01 02 03 04 05 06 18
01 02 03 04 05 06 19
01 02 03 04 05 06 20
01 02 03 04 05 06 21
01 02 03 04 05 06 22
01 02 03 04 05 06 23
#12 Re: Multi File Name Find
Posted by: pspad | Date: 2020-05-31 17:04 | IP: IP Logged
You didn't tell that order isn't important. Do you see that you never give complex information?
I have idea. Any thread you will start and won't provide enough information for solution without another bunch of questions will be locked. Thread what has no join to PSpad editor will be deleted.
After few such threads your account will be disabled.
You can easily avoid it - when you start new thread, provide complex description.
Edited 2 time(s). Last edit at 2020-05-31 17:09 by pspad.
#13 Re: Multi File Name Find
Posted by: maki | Date: 2020-05-31 18:06 | IP: IP Logged
How can you not understand a simple topic about creating a combination of 30 numbers. It cannot be explained more easily. Everyone will understand this!
#14 Re: Multi File Name Find
Posted by: pspad | Date: 2020-05-31 18:37 | IP: IP Logged
Why? Because:
Combination where order is/isn't important?
Combination where number can/can't repeat?
If everybody somewhere else you, ask somewhere else.
This topic has nothing with text editor, next time will be deleted.
#15 Re: Multi File Name Find
Posted by: joemarfice | Date: 2020-06-19 20:13 | IP: IP Logged
@pspad, I would support banning this user. Every single thread I've seen from them is rude, unintelligible, and uncooperative.
You don't need the heartburn. We don't need the noise.
#16 Re: Multi File Name Find
Posted by: maki | Date: 2020-06-23 14:14 | IP: IP Logged
I would suggest banning the user joemarfice
which limits the ability to speak freely,
Not everyone is an expert here who can substantively determine... I am experiencing suppression of freedom of speech
experience discrimination about knowledge...
If we have two numbers 1 and 2, so we have two combinations.
The same procedure applies to numbers from 1 to 80.
Each set can contain a maximum of 20 numbers (range 1-80)
Not repeat
Order - not matter
Edited 2 time(s). Last edit at 2020-06-23 14:16 by maki.
#17 Re: Multi File Name Find
Posted by: pspad | Date: 2020-06-23 14:36 | IP: IP Logged
Maki, please keep theme, put questions related to PSPad editor.
Make your questions aswerable by providing enough information an all will be OK.
