You are here: PSPad forum > English discussion forum > Re: Colorize the log window (Type Memo)
#1 Colorize the log window (Type Memo)
Posted by: Professor Bernd | Date: 2020-05-20 19:12 | IP: IP Logged
For compiling you can set the type of log win to Memo. The memo is a RichEdit. Is there a way to color the lines of the RichEdit differently?
#2 Re: Colorize the log window (Type Memo)
Posted by: pspad | Date: 2020-05-20 19:15 | IP: IP Logged
Memo isn't RichEdit, memo is plaintext memo.
#3 Re: Colorize the log window (Type Memo)
Posted by: Professor Bernd | Date: 2020-05-20 19:38 | IP: IP Logged
Too bad. But thanks for the answer!
#4 Re: Colorize the log window (Type Memo)
Posted by: pspad | Date: 2020-05-20 19:39 | IP: IP Logged
What do you want to colorize?
#5 Re: Colorize the log window (Type Memo)
Posted by: Professor Bernd | Date: 2020-05-20 19:53 | IP: IP Logged
At the beginning of a line you can write different characters (always 1 character per line), then the line is shown in a certain color (e.g. "!" = red, "+" = blue). Depending on the importance of a line, the line can be shown in the corresponding color.
Edited 4 time(s). Last edit at 2020-05-20 20:02 by Professor Bernd.
#6 Re: Colorize the log window (Type Memo)
Posted by: Professor Bernd | Date: 2020-05-21 03:37 | IP: IP Logged
Maybe you could add a RichEdit, including log parser (or replace the memo)? In VBScript "logSetTypeRiEd", "logSetLineColor(Color)", "logSetLineBKColor(Color)", ...
Log parser photomontage
This is NOT an important feature. If it is too much work, put it at the bottom of your todo list. winking smiley
