You are here: PSPad forum > English discussion forum > AutoIt3 Highlighter Error with mixed quotes
#1 AutoIt3 Highlighter Error with mixed quotes
Posted by: Professor Bernd | Date: 2020-05-13 06:53 | IP: IP Logged
If single and double quotation marks are used, there is a bug in the highlighter.
#2 Re: AutoIt3 Highlighter Error with mixed quotes
Posted by: Professor Bernd | Date: 2020-05-15 14:57 | IP: IP Logged
Is there a setting I can use to fix the problem?
#3 Re: AutoIt3 Highlighter Error with mixed quotes
Posted by: pspad | Date: 2020-05-15 15:10 | IP: IP Logged
Does autoit uses both double quotes and apostrophes for strings?
#4 Re: AutoIt3 Highlighter Error with mixed quotes
Posted by: Professor Bernd | Date: 2020-05-15 15:34 | IP: IP Logged
AutoIt uses single quotes and double quotes for strings. Very useful to use the respective other quote in code without escaping it.
Example
Also very useful for functions like In the screenshot in the first post.
Edited 1 time(s). Last edit at 2020-05-15 15:38 by Professor Bernd.
#5 Re: AutoIt3 Highlighter Error with mixed quotes
Posted by: pspad | Date: 2020-05-15 15:38 | IP: IP Logged
OK. I must take a look where is problem in code in handling both string styles together.
#6 Re: AutoIt3 Highlighter Error with mixed quotes
Posted by: Professor Bernd | Date: 2020-05-15 15:41 | IP: IP Logged
Thanks.
#7 Re: AutoIt3 Highlighter Error with mixed quotes
Posted by: pspad | Date: 2020-05-15 15:54 | IP: IP Logged
Fixed
#8 Re: AutoIt3 Highlighter Error with mixed quotes
Posted by: Professor Bernd | Date: 2020-05-16 18:19 | IP: IP Logged
Wow, very good work! smiling smiley
