You are here: PSPad forum > English discussion forum > Error in AutoIt3 Highlighter on comment
Posted by: Professor Bernd | Date: 2020-05-13 06:22 | IP: IP Logged
Text after comment characters is NOT highlighted as comment if the comment character ";" is directly (without spaces) after another character.
Posted by: pspad | Date: 2020-05-13 06:58 | IP: IP Logged
You use Basic style comment in the user highlighter declaration and Basic comment must start after space or tab.
Open User highlighter definition and check VLisp comment in the first part of comments:
It will tell PSpad that comment can start directly after text. It's temporary solution, I will make this functionality for AutoIt comment #cb..#ce too.
Will be available in the next build
Posted by: Professor Bernd | Date: 2020-05-13 08:32 | IP: IP Logged
VLisp comment works fine. Thank you very much.
Posted by: pspad | Date: 2020-05-13 09:10 | IP: IP Logged
VLips allows comment start immediately behind the word without space. I will make same exception for AutoIt comment.
In next build you can switch VLisp comment off and it will work.
Posted by: Professor Bernd | Date: 2020-05-13 09:26 | IP: IP Logged
Could you also take the opportunity to have the block comment highlighted until the end of the line?
For example
now it is:
#cs -----------------------
any text
#ce -----------------------
but it should be:
any text
Posted by: pspad | Date: 2020-05-13 09:34 | IP: IP Logged
I can't be, cause end of block ends comment. Behind the #ce can be code and it can't be highlighted as comment.
Posted by: Professor Bernd | Date: 2020-05-15 14:27 | IP: IP Logged
In AutoIt, the Comment block continues to the end of line even after the end character "#ce".
