You are here: PSPad forum > English discussion forum > Re: Search in the editor scrolls too far
Posted by: Professor Bernd | Date: 2020-05-13 06:09 | IP: IP Logged
If a search term is located on the right in the visible area of the editor, F3 automatically scrolls to the right so that the search term comes to the middle of the editor ("Default" setting). This moves the right, important part of the document out of the visible area, while on the left there is much, much empty space. How can I set the setting to scroll only so far that the search term is visible at the right margin?
Edited 1 time(s). Last edit at 2020-05-13 06:10 by Professor Bernd.
Posted by: pspad | Date: 2020-05-13 06:29 | IP: IP Logged
Scroll settings (top, bottom, middle) is for vertical position.
Horizontal is made to make search result visible.
can you send any screenshot?
Posted by: Professor Bernd | Date: 2020-05-13 09:56 | IP: IP Logged
Posted by: pspad | Date: 2020-05-16 07:44 | IP: IP Logged
From the next build search result won't be alligned horizontally to the center, I will ensure only that result is visible - horizontal scroll will be as minimal as possible
Posted by: Professor Bernd | Date: 2020-05-16 18:23 | IP: IP Logged
That's great! Very valuable! Thank you very much!
