You are here: PSPad forum > English discussion forum > Re: find first and last
Posted by: pspad | Date: 2020-05-13 07:09 | IP: IP Logged
I know how to search for other occurences and highlight them, but in the on the fly highlighting event is made a lot of other things. I must do it and don't break existing functionality, I can't speed down drawing e.t.c.
Posted by: maki | Date: 2020-05-15 14:55 | IP: IP Logged
I only want to find the specific first two numbers and even trying to match each regex fails. Why is everything that seems simple is complicated?
Not March regex:
(^39|32$([^0*([1-9]|[12][0-9]|3[0-8])|0*([4-7][0-9]|80)|0*([1-9]|[12][0-9]|3[01])|0*(3[3-9]|[4-7][0-9]|80)]))
Edited 1 time(s). Last edit at 2020-05-15 14:55 by maki.
Posted by: pspad | Date: 2020-05-15 15:08 | IP: IP Logged
Example of real line you are looking for and result.
Learn how to write question.
Posted by: maki | Date: 2020-05-15 16:10 | IP: IP Logged
Find: 58,21
and
20,50
Match:
58,61,23,46,20,25,74,29,09,12,03,64,44,15,11,24,45,73,37,21
20,44,69,80,26,16,23,09,36,76,37,61,58,21,49,04,08,28,10,50
Non-Match
58,61,23,46,20,25,74,29,09,12,50,64,44,15,11,24,45,73,37,28
Edited 5 time(s). Last edit at 2020-05-15 16:13 by maki.
Posted by: pspad | Date: 2020-05-15 16:17 | IP: IP Logged
Are you looking for lines starting with 58 and ending with 21 or do you want to find first and last number?
Those things are different and you should know first what do you want.
When you look on start of this topic, you will find your request on the begin was totally different from your request now.
Posted by: maki | Date: 2020-05-15 16:20 | IP: IP Logged
I just want to insert any numbers (first and last) and always ignore the second to nineteenth number.
Posted by: pspad | Date: 2020-05-15 16:23 | IP: IP Logged
I don't understand you "insert numbers"
Try again from the begin and describe your problem complexly
Posted by: maki | Date: 2020-05-15 16:30 | IP: IP Logged
The ones I'm looking
I say I want to find the first and last number.
Must match start and end.
If I enter e.g. 44,56
So I want to find all the lines that contain these numbers at the beginning and end.
Posted by: pspad | Date: 2020-05-15 16:54 | IP: IP Logged
So I wil lreturn to my forst answer:
forum.pspad.com
Search: ^44.*56$
If you want to look for more pairs, use this: ^(58.*21|20.*50)$
Edited 1 time(s). Last edit at 2020-05-15 16:57 by pspad.
Posted by: maki | Date: 2020-05-15 18:10 | IP: IP Logged
The expression is incorrect because it matches the whole string and should only mark 2 numbers!
Test: regex101.com
I need a macro script
Edited 3 time(s). Last edit at 2020-05-15 18:16 by maki.
