You are here: PSPad forum > English discussion forum > Re: Highlighting all occurrences of selected text in the active editor
Posted by: pspad | Date: 2020-06-26 19:21 | IP: IP Logged
brolx:Inconsolata or Lucida Console.
Because you asked, I tried both 11 and 12. The problem only occurs with 11.
My resolution is 1920x1080 (scaling 100%)
I can confirm problem with Lucida Console, this font is painted by editor component with bigger spaces between chars (I don't know why). But I can't confirm it with Inconsolata. I downloaded and installed Inconsolata regular.
I prefer modern fonts like Consolas instead of the old Lucida console or Courier New. If you need good programmer font, try Liberation Mono.
Posted by: Professor Bernd | Date: 2020-06-26 23:12 | IP: IP Logged
pspad:If you need good programmer font, try Liberation Mono.
Good tip!
Posted by: brolx | Date: 2020-07-03 09:02 | IP: IP Logged
any idea about what I could do to solve the problem?
Posted by: brolx | Date: 2020-07-03 09:45 | IP: IP Logged
Liberation Mono solves the problem.
I have to get use to this new font, but it's a good work-around.
Thanks
Posted by: pspad | Date: 2020-07-03 09:59 | IP: IP Logged
I must find a way how to paint it. There is problem of some fonts - they didn't show correct width. PSpad paints standard content char by char. When I paint other occurences, I paint it as whole string and it causes difference.
The easiest way is to paint it same way as editor component. It will solve problem with all fonts.
