You are here: PSPad forum > English discussion forum > Re: html code formatting (pretty print)
#1 html code formatting (pretty print)
Posted by: kdb | Date: 2020-03-24 11:27 | IP: IP Logged
The function html code formatting (pretty print) leads to the following result.
It used to be different. I probably accidentally changed something.
wrong
<?xml version="1.0" encoding="UTF-8"?>
<se >
<Partner >
<guid>DA020000-47F6-1020-8D-6D-0000FAC8A8C0
</guid>
<number>000952
</number>
<name>test
</name>
<updateInfo>
<createTime>2005-02-23T14:55:07.808Z
</createTime>
</updateInfo>
<MaintainingOrganization>
<type>INTERNAL
</type>
</MaintainingOrganization>
<Employee>
<employeeNumber/>
<EntityExtension/>
</Employee>
</Partner>
<Partner xmlns="com.cisag.app.general.obj.Partner">
<guid>CDD90000-DAEF-1025-B1-5F-00000F0AA8C0
</guid>
<number>013521
Right
<?xml version="1.0" encoding="UTF-8" ?>
<se>
<Partner>
<guid>DA020000-47F6-1020-8D-6D-0000FAC8A8C0</guid>
<number>000952</number>
<name>test</name>
<updateInfo>
<createTime>2005-02-23T14:55:07.808Z</createTime>
</updateInfo>
<type>INTERNAL</type>
<Employee>
<employeeNumber />
<EntityExtension />
</Employee>
</Partner>
<guid>CDD90000-DAEF-1025-B1-5F-00000F0AA8C0</guid>
<number>013521</number>
who can help me
#2 Re: html code formatting (pretty print)
Posted by: pspad | Date: 2020-03-24 11:33 | IP: IP Logged
Use integrated TiDy on the bottom of HYML menu. You can create own settings.
Or try to use reformat html from the html menu, it's simple but it can fulfill your needs
Edited 1 time(s). Last edit at 2020-03-24 11:35 by pspad.
