You are here: PSPad forum > English discussion forum > problem
Posted by: Esgrimidor | Date: 2020-03-23 14:11 | IP: IP Logged
Exception address:
Stack list, generated 23/03/2020 14:04:25
(See forum.pspad.com)
Also please describe most exact what you have done
- For example:
- PSPad runs for x hours.
- I had n files open.
- I had expected:
- But I got instead:
- I had verified that with:
--- older/newer builds
--- on other Computers
Thanks
INFO
Program : C:\Program Files (x86)\PSPad editor\PSPad.exe 5.0.4 (381)
System : Windows 10 Home Edition x64, Version: 10.0, Build: 47BA,
Processor: Intel, Intel(R) Core(TM) i7-9750H CPU @ 2.60GHz, 2590 MHz MMX
Active Controls Hierarchy:
"_X94704222"
and with a text capturer
Access violation at address 00000000008B12AO ¡n module
'PSPad.exe'. Read of address 0000000000000622.
K's very important you write a comment to this exception (in English). In ideal case,
send me sequence step by step to simúlate exception. Try to find dependencies. Your
effort will be useful for all PSPad users. Thank you.
Your exception comment:
this was with 5.0.3 367in portable mode
then I tried the last develop version in the system.
But the problem continues.
Best Regards
Nice program indeed
Edited 1 time(s). Last edit at 2020-07-09 18:24 by Stefan.
Posted by: Esgrimidor | Date: 2020-03-23 14:16 | IP: IP Logged
I observ I have a windows update pending.
So I reiniate.
Trying again. I will comment.
Nice program indeed
Posted by: Esgrimidor | Date: 2020-03-23 14:20 | IP: IP Logged
my problem continues after reinitiating.
Must be some type of corruption I think.
Happen in the portable installation and in the system installation.
I usually open a project of files. Only open 4 of many more and the content seems corrupt.
Nice program indeed
Edited 1 time(s). Last edit at 2020-03-23 14:22 by Esgrimidor.
Posted by: Esgrimidor | Date: 2020-03-23 14:26 | IP: IP Logged
Esgrimidor:my problem continues after reinitiating.
Must be some type of corruption I think.Happen in the portable installation and in the system installation.
http: //imagizer.imageshack.com/img922/3775/DeSO3d.png
Nice program indeed
Posted by: pspad | Date: 2020-03-23 15:41 | IP: IP Logged
If you open any of your file in notepad, content is OK? If not, it's problem of operating system, cause content of your file was replaced with zeroes or file table targets to another place of HDD
Posted by: Esgrimidor | Date: 2020-03-23 16:32 | IP: IP Logged
content is ok in notepad or other text editor.
Fails with pspad.
Best Regards.
How can I depure this problem ?
Nice program indeed
Posted by: Esgrimidor | Date: 2020-03-23 16:34 | IP: IP Logged
may be pspad something need to do or write ?
Some file disconfigured inside pspad ?
Nice program indeed
Posted by: pspad | Date: 2020-03-23 16:56 | IP: IP Logged
Does your files have TXT extension?
Check PSPad subfolder - .\plugins.filetype\
if there isn't any txt.exe (txt.cmd, txt.bat) file. Remove it.
Open menu Settings / Variables
On the System variables tab look at %PSPath% and ensure it's the correct PSPad you want to run.
Edited 1 time(s). Last edit at 2020-03-23 16:59 by pspad.
Posted by: Esgrimidor | Date: 2020-03-23 20:33 | IP: IP Logged
Posted by: Esgrimidor | Date: 2020-03-23 20:35 | IP: IP Logged
