You are here: PSPad forum > English discussion forum > Re: Advanced search and removal methods simultaneously
#1 Advanced search and removal methods simultaneously
Posted by: maki | Date: 2020-03-22 16:02 | IP: IP Logged
What to add to a matching expression and delete everything else at the same time? Reduce operations to the smallest possible steps.
#2 Re: Advanced search and removal methods simultaneously
Posted by: pspad | Date: 2020-03-22 16:16 | IP: IP Logged
Already implemented
#3 Re: Advanced search and removal methods simultaneously
Posted by: maki | Date: 2020-03-22 17:13 | IP: IP Logged
In which version is e.g.
"Select non-matching"?
#4 Re: Advanced search and removal methods simultaneously
Posted by: pspad | Date: 2020-03-22 17:16 | IP: IP Logged
It's few overs there in find dialog
#5 Re: Advanced search and removal methods simultaneously
Posted by: maki | Date: 2020-03-22 18:17 | IP: IP Logged
Where is the option automatically selects in the current open tab?
list, count, copy, create bookmarks
These are not expected functions!
Edited 1 time(s). Last edit at 2020-03-22 18:18 by maki.
#6 Re: Advanced search and removal methods simultaneously
Posted by: maki | Date: 2020-03-23 10:53 | IP: IP Logged
Where is "Inverse Select" / "Inverse result" etc. Hm?
Edited 1 time(s). Last edit at 2020-03-23 10:53 by maki.
#7 Re: Advanced search and removal methods simultaneously
Posted by: pspad | Date: 2020-03-23 11:19 | IP: IP Logged
Get result of all except matching into new tab:
[x]Search nonmatching
Copy button
Get result of all matching into new tab:
[ ]Search nonmatching
Copy button
This is answer to your initial question.
I see you have many one sentence (without explanation) questions not related to your first one as usually.
#8 Re: Advanced search and removal methods simultaneously
Posted by: maki | Date: 2020-03-23 12:58 | IP: IP Logged
I tested everything and still copies some or all, the program does not select text (and of course it must also do it in one window = NOT multi Tab)
In principle, operation similar to another function, when the program automatically selects everything that cannot be saved with the default encoding. And it has just such a similar function.
I checked similar issues in various forums. Nowhere is what I expect.
Yes, someone suggested that someday he would implement this function in some editor.
Edited 2 time(s). Last edit at 2020-03-23 13:02 by maki.
