You are here: PSPad forum > English discussion forum > Re: adding 3 KeyWord sections and 1 Variable section
Posted by: Professor Bernd | Date: 2020-03-02 09:10 | IP: IP Logged
All variables start with "$" and may contain one or more underscores "_". Examples:
Variables
$_iCounter
$sStringVar1
$s_String_Var_1
$g__sStringVar1
$g_sStringVar_1
MsgBox Constants
$MB_SYSTEMMODAL
$MB_ICONWARNING
Here is a code snippet, with common variable constellations.
Global $g_sFilePath = @ScriptDir & '\Testdateien'
Global $g_iKeepFiles = 5
Global $g_aFileList[0]
DeleteOldestFiles($g_sFilePath, $g_iKeepFiles, "*.zip")
Func DeleteOldestFiles($_sFolderPath, $_iNumberOfFilesToKeep, $_sFileMask = "*")
Local $iDateMode = $FT_MODIFIED ; 0 = $FT_MODIFIED (Standard), 1 = $FT_CREATED, 2 = $FT_ACCESSED
Local $iFileCount = 0
Local $sFileList = ""
Local $hFiles = 0
Local $iIdx = 0
Local $iRet = 0
If Not FileExists($_sFolderPath) Then
MsgBox($MB_SYSTEMMODAL + $MB_ICONWARNING, "FileQuantityLimit Error", _
"Folder does not exist: ''" & $_sFolderPath & "'' ")
Exit
EndIf
If you meant an example script, I would be happy to send you one.
Bernd.
Edited 1 time(s). Last edit at 2020-03-02 09:14 by Professor Bernd.
Posted by: Professor Bernd | Date: 2020-03-02 09:48 | IP: IP Logged
Here is another example _GUICtrlRichEdit_GetSel
Posted by: Professor Bernd | Date: 2020-03-17 09:39 | IP: IP Logged
Were those source samples okay for you?
Posted by: pspad | Date: 2020-03-17 10:28 | IP: IP Logged
Yes, files are ok. But please be patient. Hectic time now.
Posted by: Professor Bernd | Date: 2020-03-17 15:23 | IP: IP Logged
No problem, this feature is not urgent.
Posted by: Professor Bernd | Date: 2020-03-30 08:18 | IP: IP Logged
Hello Jan.
In the new version you have added the "_" to 'PHP style variable' in the user highlighter. Many thanks for that!
Now only the "$" is missing. It works if I remove the "$" character from the autoit keyword chars. But, as I wrote in posting #9, I can't remove '$' from the autoit keyword char. This would prevent variable detection in all functions that use the %Word% variable, e.g. the Language Help and some of my VBScripts. Another example is when I double-click a varialbe, it is not completely marked for copying, deleting, etc.
Is there a way to add the "$" to variable highlighting without removing it from the keyword chars? The "_" is also in the keyword chars, and highlighting works perfectly for this character.
Bernd.
Posted by: pspad | Date: 2020-03-30 08:37 | IP: IP Logged
Now I underdstand. This is separate problem.
The right solution is:
remove $ from keyword char
correctly handle word selection when highlighting of variable is available.
Posted by: Professor Bernd | Date: 2020-03-30 08:53 | IP: IP Logged
Please excuse me, my English is not so good. Could you explain more precisely how I could do it?
pspad:remove $ from keyword char
That's clear.
pspad:correctly handle word selection when highlighting of variable is available.
How exactly can I do that?
Bernd.
Posted by: pspad | Date: 2020-03-30 09:07 | IP: IP Logged
The second part is up to me, I must change program
When change will be done, you can remove $ from keywords, but word selection will correctly mark whole word include '$' char
Posted by: Professor Bernd | Date: 2020-03-30 09:17 | IP: IP Logged
Oh, very well. Thank you very much.
Bernd.
