You are here: PSPad forum > English discussion forum > How to disable Syntax check HTML file?
#1 How to disable Syntax check HTML file?
Posted by: maki | Date: 2020-02-14 16:43 | IP: IP Logged
How to disable Syntax check HTML file in PSPad?
#2 Re: How to disable Syntax check HTML file?
Posted by: pspad | Date: 2020-02-14 16:50 | IP: IP Logged
I don't understand
#3 Re: How to disable Syntax check HTML file?
Posted by: maki | Date: 2020-02-14 17:13 | IP: IP Logged
Disable ability to check syntax of HTML, XHTML, CSS, and JSON documents?
#4 Re: How to disable Syntax check HTML file?
Posted by: pspad | Date: 2020-02-14 17:15 | IP: IP Logged
PSpad doesn't do any syntax check. I repeat, I don't understand you.
Maybe you don't want to highlight syntax. In this case press toolbar button or use menu View
#5 Re: How to disable Syntax check HTML file?
Posted by: maki | Date: 2020-02-14 17:27 | IP: IP Logged
winking smiley Yes. Thanks.
